Activity Forums Maxon Cinema 4D Normal Direction in Alpha Channel not working?
  • Normal Direction in Alpha Channel not working?
    Posted by Caroline Anthony on September 21, 2015 at 5:47 pm
    Hey all,
    I’m trying to make my model into a transparent alpha mask for the structures around it. I put a material on it, unchecked everything but ‘Alpha’, changed the texture to ‘Normal Direction’ and it just isn’t working. The model comes out solid black. Oddly enough, if I go inside the model and look out the alpha channel works. I tried reversing the normals but that didn’t work. Does anyone know what I’m doing wrong?
    Any help appreciated!
    Caroline Anthony replied 11 years ago 2 Members · 2 Replies
  • Adam Trachtenberg
    September 21, 2015 at 9:40 pm
    Did you try unchecking “Invert” in the alpha channel properties?
  • Caroline Anthony
    September 21, 2015 at 9:57 pm
    Hey Adam,
    Thanks for responding. Yes, ‘Invert’ was unchecked when I first started trouble shooting. It is the oddest thing. I found a work-around for now, but I still would love to figure out what the problem was.
