Activity › Forums › Adobe After Effects › Nooby question. Where is the hue stopwatch?
  • Nooby question. Where is the hue stopwatch?
    Posted by Ian Dillon on December 14, 2009 at 9:16 pm
    How come there is no way to animate the hue control? I don’t see the stopwatch. Is there another way to do this?
    Thanks in advance.
    Anton Frolov replied 9 years, 8 months ago 5 Members · 7 Replies
  • 7 Replies
  • Todd Kopriva
    December 14, 2009 at 10:44 pm
    Taking a step back here:
    Since you said that you’re new, I figured that you wouldn’t mind if I went back to basics.
    Each layer has properties. Most properties have stopwatches, which means that you can animate them. You add additional properties to a layer in a few ways, including by applying effects. To add a hue property to a layer, you can add the Hue/Saturation effect.
    There’s some more basic information on this page and the pages that it points to.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Ian Dillon
    December 15, 2009 at 10:16 am
    I’m not really new. It was just a nooby question.
    The hue control in the Hue/Saturation effect has no way to animate it because it doesn’t have a stopwatch thingy. What is the normal workaround? I forgot.
    Thanks in advance.
    Ian.
    Playroom Creative
    http://www.playroomcreative.com
  • Ian Dillon
    December 15, 2009 at 10:21 am
    There is no animation stopwatch for the Master Hue control in the Hue/Saturation effect. What is the normal workaround?
    Thanks in advance!
    Ian.
    Playroom Creative
  • Ian Dillon
    December 15, 2009 at 10:26 am
    So the “Color Range” stopwatch controls the Hue, Saturation and Lightness??
    Playroom Creative
  • John Cuevas
    December 15, 2009 at 3:17 pm
    Check the colorize checkmark and there are individuals controls for Hue,saturation and lightness.
    Johnny Cuevas, Editor
    http://www.ckandco.net
  • Bob Root
    December 16, 2009 at 4:42 pm
    Probably the best solution for key-framing hue (and other color properties) will be through the SA Color Finesse plug-in. It’s included in the plug-in package for CS3 and CS4.
    There are a couple of posts in the Synthetic Aperture forum on the Cow regarding removing the water mark. There should be a separate serial sticker for SA Color Finesse on the box your AE came in. If it’s not there (apparently some boxes went out without the extra sticker), you can get it by contacting Adobe.
    Hope this helps.
    Bob
  • Anton Frolov
    December 21, 2016 at 8:25 pm
    There is a COLOR BALANCE (HLS) effect. You’re gonna find it
