Activity › Forums › Maxon Cinema 4D › Noob wants to do a turntable animation in Cinema 4D
  • Noob wants to do a turntable animation in Cinema 4D
    Posted by Kevin Michael on August 30, 2013 at 7:06 pm
    I’m VERY new to Cinema 4D. I’ve imported a 3D model of a human head. All I need to do is export a video of that head spinning around once. I want the head to rotate from 0 to -360 degrees over the course of about 4 seconds so that the exported video will loop continuously. How do I do this? I’m sure it’s very simple, but I can’t find a tutorial that tells me how. Thanks!
    Tim Shetz replied 13 years ago 2 Members · 2 Replies
  • Tim Shetz
    August 31, 2013 at 12:09 am
    I have a turntable tutorial here:
    Turntable Tutorial
    I used a helix in my tutorial, but you could select a circle instead.
    Hope it helps. Let me know if you have questions.
    __________
    Tim Shetz
    c4dtraining.com
  • Tim Shetz
    August 31, 2013 at 12:20 am
    I did use a circle… been a while.
    One thing to be aware of is that if you are going to loop the animation…Cinema auto eases the keyframes, so you’ll get a speed up at the beginning and a slow down at the end. If you plan on looping you’ll need to change the interpolation of the two keyframes.
    As you’ll see in the comments, there are several ways to do this exact thing. You could animate the circle rather than the position of the Align to Spline tag.
    __________
    Tim Shetz
    c4dtraining.com
