Activity › Forums › Storage & Archiving › Noob questions….
  • Fred Jodry
    December 19, 2010 at 3:55 am
    Your two new RAID 0? drives will backup and restore with no mentionable incompatibilities with the (plug in single drives?) predecessor. The question you will want to ask yourself in the future, sometimes, is whether you should improve the speed of the backup, restore archives operation. For instance, some setups now use a backup, restore array that actually has more speed than the work computer on hand, and can be switched off, complete witth maybe a booster Xeon processor in it integrally switching on and off with it (or faster or slower) at the same time. The reason for the faster backup and restore is mostly so that backup and restore don`t have to be forced into off- peak times, (or do you want your technician to be on the job at 3 o`clock in the morning when hardware or the job is having a hard time)? Another reason for powerful, adjustable power backup and restore is that it saves electricity compared to having a work computer pushing backup the brute force way. A stack of Xeons render farm can run up an electric bill that pushes a production joint out of business. I also noticed that you`re talking about hard drives to hard drives as archiving. You may want to use tape or other archives in the future.
