Activity › Forums › Maxon Cinema 4D › Noob question regarding bump channels and extruded shapes.
  • Noob question regarding bump channels and extruded shapes.
    Posted by Diego Massanti on May 24, 2009 at 9:57 pm
    Hello there, im new to 3d modeling and even the fact that i have been able to do all i wanted to do so far, i have a question…
    Im working on a 3d model for my city’s shield, and as you can see in the following picture, the bump channel for the gold-like base is showing ok EXCEPT on the filleted borders created with the extrude nurbs modifier….
    (you might have to click on the image to see it full-size in order to see what im talking about )
    How can i make the bump channel to show on the extruded sides even if there are filleted caps ? is that possible ?
    Thanks in advance, Diego.
    Cheers.
    Diego Massanti.
    Steve Bell replied 17 years, 3 months ago 3 Members · 2 Replies
  • Nolan Scott
    May 25, 2009 at 5:33 am
    In the Texture Tag (Attributes Manager) change the Projection to “Cubic”..
    (does that make any difference…?)
    Regards
    Nolan
  • Steve Bell
    June 7, 2009 at 10:33 am
    I know this problem well. The instant fix is to change the texture mapping from the default UVW method to something else, possibly cubic, see what works best. I use NURBS a lot, especially on all the furniture we model for our architectural renderings/animations. It would be great if C4D could handle these better or with an alternative method of generating UVW coordinates.
    Steve Bell
    http://www.archiform3d.com
