Activity › Forums › Maxon Cinema 4D › Noob question: how can I make particle clouds sit behind the floor’s horizon
  • Noob question: how can I make particle clouds sit behind the floor’s horizon
    Posted by Simon Lucas on December 2, 2019 at 2:23 pm
    New to c4d:
    I’ve made particle clouds (Pyrocluster) and now want to have them ‘in the sky’ – so sitting behind a horizon line in my drawing. At the moment, I’ve added a floor object, but have tried a large disk, too.
    (NB. I find the c4d sky object too complex at the moment, and I like the clouds I made so would like to try and make them work).
    Just wondered if there’s a simple way to do this?
    Thank-you
    Files:
    https://we.tl/t-LmeSnnmiGQ
    Simon Lucas replied 6 years, 9 months ago 1 Member · 1 Reply
  • Simon Lucas
    December 2, 2019 at 5:20 pm
    I can see that using a large disk as the ground, and positioning the particle emitter outside to the rear of the scene, it will give the effect I need. I just need to find a way to scale up, the now distant emitter, so the clouds look like the ones in the test picture.
