Activity Forums Maxon Cinema 4D noob question: black cube with white edges
  • noob question: black cube with white edges
    Posted by Bert Brown on June 27, 2008 at 4:43 pm
    I’m trying to get a cube to be black with white edges. How do i do this?
    I thought i could use a selection set, but doesnt seem to be doing the trick.
    peep my over-the-interweb band, red abbott.
    “we electro-rock over long distances…”
    Brian Jones replied 18 years, 2 months ago 3 Members · 2 Replies
  • Randy Johnson
    June 27, 2008 at 4:52 pm
    In bodypaint this is extremely simple in Bodypaint.
    Some video Tutorials here that can show you the way…
    https://www.c4dcafe.com/ipb/index.php?autocom=downloads&showcat=3
    Or you could use a cell render and change the colors to what you want.
    /randy
  • Brian Jones
    June 27, 2008 at 6:32 pm
    Selection set could work if you selected all the faces did an inner extrude, take a selection set from the inner faces and apply a white texture and a black texture that uses the selection set.
    another way would be to make a square texture black with white edges, use that as the color channel in a texture and apply the texture with Cube mapping.
