Activity › Forums › Maxon Cinema 4D › noob question about sweep nurbs
  • noob question about sweep nurbs
    Posted by Guy Slator on June 20, 2019 at 12:50 pm
    I’m just wanting to use 2 splines and a sweep to create some geometry between two sections. How do I get the geometry to sit between the 2 splines, at the moment (as pictured) they are not attached.
    Brian Jones replied 7 years, 3 months ago 2 Members · 3 Replies
  • Brian Jones
    June 20, 2019 at 5:14 pm
    post the scene file please
  • Guy Slator
    June 20, 2019 at 8:20 pm
    There you go
    13459_sweep01.c4d.zip
  • Brian Jones
    June 20, 2019 at 9:22 pm
    I see, you really are using only two splines in a Sweep (without using a Rail Spline) the functionality is
    Sweep
    – spline (spline that gets swept)
    – spline (along this spline)
    Because your splines are not at the origin point it looks offset from the ‘along this’ spline. What you want (I think) is not a Sweep but a Loft. If you put two splines in a Loft it will make geometry to join the two.
