Activity Forums Blackmagic Design Noob Problems?
  • Noob Problems?
    Posted by Dean Decarlo on November 20, 2006 at 8:01 pm
    I bought and installed a new Decklink Extreme on Friday. Worked fine. Now I boot up today and everything is weird. At first the card wouldn’t get recognized. Reinstalled drivers. Worked ok BUT now I can’t set my main display to anything higher than 1280×1024. Strange. I’ve reinstalled the Nvidia drivers. I want to run at 1600×1200 but every time I try the Nvidia card (7900gs) goes to 640×480. Any ideas?
    Dean
    Dean Decarlo replied 19 years, 9 months ago 2 Members · 2 Replies
  • Martin Kraut
    November 21, 2006 at 9:13 am
    You are on the wrong monitor setting.When you install a BMD card in a Dual Montor system,you will see 3 monitors to configure (Display properties).The 3rd is called Blackmagic display.The only possible resolutions for this monitor are Pal and NTSC Resolutions.Be sure to disable “extend Windows Desktop ” for this monitor.
  • Dean Decarlo
    November 21, 2006 at 9:26 pm
    That’s not it. I did disable extend. BMD was always 720×286. And there are only two monitors. What should the third be? The Nvidia composite output?
    Thanks for the reply.
