Activity Forums Apple Final Cut Pro Legacy noob problem cutting a clip
  • noob problem cutting a clip
    Posted by Baba Goof on May 20, 2005 at 7:57 pm
    i’m cutting something shot with four cameras. i have them synced in the
    timeline (someone else has done the setup – cam1 on trk1, cam2 on trk2,
    etc., with trk5 being a rendered out 4way split showing all four cameras).
    i’ve been making cuts across all tracks and moving the selected camera
    for each cut up to track 6. occassionally, when i use control-v to make a
    cut, one or more of the clips seems immune to the cut. a right click shows
    it to be enabled and the track is not locked. can someone point me to how
    i can get these clips to cut with the rest of the clips?
    thanks,
    BabaG
    Baba Goof replied 21 years, 3 months ago 2 Members · 2 Replies
  • You need to have the AUTO SELECT icon ON for the track(s) you wish to cut.
    They are the “square in the cross” icons just to the right of the little track-lock padlock icons.
  • Baba Goof
    May 21, 2005 at 2:03 am
    thanks. i’ll check that on monday.
