Activity Forums Apple Final Cut Pro Legacy noob key command question
  • noob key command question
    Posted by Baba Goof on June 1, 2005 at 5:43 pm
    if i copy a clip (command c), what is the key command to drop
    it into the timeline at the cursor position? how do i switch
    this command between ripple and overwrite? or is it a different
    command? is there a printable list somewhere of default keyboard
    commands?
    thanks,
    BabaG
    Baba Goof replied 21 years, 3 months ago 4 Members · 6 Replies
  • Scott Davis
    June 1, 2005 at 6:06 pm
    Command (open apple) “v” is the paste command. By defauldt FCP will paste it into the tracks that the original clip is in. I don’t think you can specify an overwrite or insert with a paste. An easy way to do that is to position your cursor where you want the clip, click and drag the original clip into the canvas onto either the insert or overwrite overlays. I think there is a list in the PDF manual of the keyboard shortcuts. Or you can open the keyboard layout in the “tools” menu to see what each key does ( it has a nice search feature also).
    Scott Davis
  • Baba Goof
    June 1, 2005 at 7:14 pm
    thanks scott. is there a way i can just drag a clip from one place to another and have it ripple? what has to be selected, or how do i get into the proper mode to do this? sorry for the noob-ness.
    BabaG+
  • Jason Mccaffrey
    shift-v will do an insert edit.
  • Arthur Vibert
    June 1, 2005 at 7:28 pm
    If you want to move it around once it’s in the timeline, you can start to drag it, then press the OPTION key, and the arrow will acquire a curve. Then you can drop it in wherever you want and the timeline will ripple to accomodate it.
    Arthur VIbert
  • Baba Goof
    great! thanks. and what does an overwrite edit?
  • Baba Goof
    June 1, 2005 at 7:29 pm
    great! perfect! thanks arthur.
