Activity Forums Apple Final Cut Pro Legacy noob 2 questions
  • noob 2 questions
    Posted by Baba Goof on May 3, 2005 at 2:29 am
    i’m about to start working with someone on a final cut system and have a couple of
    questions. some of our material is multi camera material. how hard is it to create
    a composite qt file that has all four cameras in a four way split screen. i’d like
    to do this as a reference file for the various cams. second question is about 24pa.
    how does fcp handle this? does it strip the extra frames from the tape as it’s
    digitized, leaving only 24fps on the disk? or does it digitize all 30fps and have
    a routine in the app for pulling down to 24? trying to figure out in what state
    the captured files exist on the disk.
    thanks,
    BabaG
    Baba Goof replied 21 years, 4 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    May 3, 2005 at 4:10 am
    If you capture 24pa with the option of removing the pulldown pattern on the fly, they will be 24fps files…
    If you scale each camera down to about 45% in the Motion Tab, you can easily layer them and arrange them in the Canvas so you can see them all… then if you want you can export this file as a self contained QT movie.
    If you can wait until FCP 5 comes out some time this month… it’s new multicam editing is really quite robust and easy to do…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Baba Goof
    May 3, 2005 at 8:26 am
    thanks jerry!
