Non-Writable Scratch Disks – Trying to open FCP and can’t
Hello,
So I’m trying to open up Final Cut Pro, using a different hard drive. Every time I try, It won’t allow me to open it. A window called ‘Non-Writable Scratch Disk comes up and says:
One or more of the scratch disks you have specified does not have read/write access. To preserve the integrity of the data used by Final Cut Pro, it is necessary to ensure read/write access to the following path(s).
Then it shows my old external drive that I used for another project (that I don’t want to use again), and gives me the option to QUIT, CHECK AGAIN, or RESET SCRATCH DISKS. I’ve tried clicking CHECK AGAIN, but it just says that my old hard drive is missing. Should I press RESET SCRATCH DISKS??
