Activity Forums Adobe After Effects non square pixel problems
  • non square pixel problems
    Posted by Edamame on August 22, 2005 at 6:57 pm
    Ok, I’m working on an HD project and am using AE 6.5 Pro.
    The footage was shot on a Panasonic VariCam @ 23.976 fps and @ 29.97
    both are Non-Square (1.33:1) pixels 1280 x 720 DVCPRO HD 720p60
    Seems like the panasonic shoots rectangular wide pixels and then Final Cut or other programs recognize that and squish it down a bit and make the pixels square in the end.
    problem is After Effects seems ok with importing and expoting the footage as is, BUT i can’t seem to create non-square graphics for this footage. I’ve either had to put the footage into a Square Pixel Comp and scale down the footage width 25% and work on top of that or work by scaling up my square pixel graphics to match the non square comp.
    What do you guys do when you work in HD with Non-Square footage? Has anyone run into this problem?
    I’m also using Synth Eyes to track some of the shots and am having trouble with the non square pixels in that too!
    please help!
    thx
    -justin!
    Edamame replied 21 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
