Activity Forums Adobe Photoshop Non square pixel conversion
  • Non square pixel conversion
    Posted by Renato on November 6, 2005 at 12:51 pm
    Hello,
    I have about 200+ images that I need to bring into Premiere for a simple slide show. They are all different dimensions, but they are all square pixels. I need to convert all of them to non square, since they are showing up completely distorted in Premiere.
    I have no idea on how to do it with all the different sizes I have, and I dont want to resize each and every image manually.
    Is there a way to automate this? hope my obvious confusion on the subject doesnt make my question too unclear..
    thanks for any help or ideas
    renato
    Renato replied 20 years, 10 months ago 2 Members · 4 Replies
  • Richard Harrington
    November 6, 2005 at 2:41 pm
    Would help if you told us WHICH version of Photoshop you are using
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Renato
    November 6, 2005 at 2:59 pm
    Sorry Richard, bad mistake.. I am using CS2, and I had no idea it came with Video Actions. I just found it on the manual.. I tried “DVD Slideshow NTSC Standard Inset” and apparently my problems are solved.
    Any ideas or comments if this is a good aproach are highly appreciated. Thanks again for helping me out.
    renato
    November 6, 2005 at 6:28 pm
    Since I wrote those Actions.. they were going to be my suggestion (grin) if you had CS2….
    You can also use the Place command and mannually place a bunch of images into a non-square comp and size by hand if you want.. the NS conversion happens upon the Place command
  • Renato
    November 6, 2005 at 6:37 pm
    oh wow..thats really cool!!
    they worked perfectly for what I needed. And thanks for the tip about the place command. I know its gonna be usefull in future projects.
    sorry again for not mentioning the version and thanks for the great actions!
    renato
