Activity › Forums › Adobe Premiere Pro › non-rendered playback
  • non-rendered playback
    Posted by Ron Pestes on November 23, 2011 at 11:50 pm
    How do I get clips to play back smoothly that have been stablized in AE? I have to play them several times to get the render cache done before it plays smoothly. This happens everytime I open the project, it has to go through the clips several times before I get smooth play back. Is there some way to keep it playing correctly? This happens regardless of what the playback settings command is set at.
    ronpesteshdvideo.com
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
    Dell M6600
    New convert to Adobe CS5.5 Production Premium
    Todd Kopriva replied 14 years, 10 months ago 4 Members · 9 Replies
  • 9 Replies
  • Chris Tompkins
    November 24, 2011 at 2:17 pm
    why not render it?
    Chris Tompkins
    Video Atlanta LLC
  • Ron Pestes
    November 24, 2011 at 4:36 pm
    It gives me a yellow line and it only renders red lines. Using a certified Nvidia 3000m card, 16 gig of RAM and a 2820q i7 processor.
    Sony EX-3
    MacBook Pro
    Dell M6600
  • Tom Daigon
    November 24, 2011 at 5:04 pm
    Ron. make sure the Work Area Bar (right above the timeline) covers the clips you need rendering, then select Rend All Work Area. That should do it. If for some weird reason it doesn’t, this workaround will. Place the video effect “Fast Blur” set to 0 on your clip. It wont change a thing, but it will force a render. The first option should really work.
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Ron Pestes
    November 24, 2011 at 6:02 pm
    Thanks Tom, problem solved!
    Sony EX-3
    MacBook Pro
    Dell M6600
  • Tom Daigon
    November 24, 2011 at 11:03 pm
    You’re welcome Ron. Which solution did you use?
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Ron Pestes
    November 25, 2011 at 12:52 am
    Just setting the range and telling it to render the work area did the job. Coming from FCP I am still getting used to the slightly different commands. Overall I really like the application and am now fairly comfortable with it. Learning After Effects is next.
    Sony EX-3
    MacBook Pro
    Dell M6600
  • Tom Daigon
    November 25, 2011 at 2:35 am
    I recently made the switch as well. You are right. There are lots of little differences between them. This book helped orient me and serves as an ongoing reference. I highly recommend it!
    https://www.amazon.com/Editors-Guide-Adobe-Premiere-Pro/dp/0321773012/ref=sr_1_1?ie=UTF8&qid=1322188434&sr=8-1
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Ron Pestes
    November 25, 2011 at 3:11 am
    Yes, I just finished that one and also “Adobe Premiere Pro CS5 and CS5.5 Digital Classroom”. They both have there good points. Just starting my first Encore project next.
    Sony EX-3
    MacBook Pro
    Dell M6600
  • Todd Kopriva
    November 25, 2011 at 6:21 am
    There’s more information about rendering preview file here, including suggestions for mapping the command for rendering entire work area to a keyboard shortcut.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
