Activity Forums Adobe After Effects Non-overlapping borders/strokes with layered Shape Layers?
  • Non-overlapping borders/strokes with layered Shape Layers?
    Posted by Eric Chard on January 31, 2021 at 9:10 pm
    I’m animating the classic “Ikegai” Venn diagram, using shape layers. These are 4 colored circles with white borders. While I want the color fills to overlap and affect each other, I want the white borders to ignore the layer stacking order and always appear 100%, no matter where they are in the stacking order and what’s overlapping them.
    Can this be done without adding a lot of parented circle layers that would track the position of “their” fill layers?
    Eric Chard replied 5 years, 6 months ago 3 Members · 3 Replies
  • Walter Soyka
    January 31, 2021 at 11:07 pm
    Can you use an Add or Screen blend mode to accomplish the layering you want?
  • Robert Müller
    February 1, 2021 at 9:18 am
    You can assign different blend modes for fill and strokes inside the shape layer. You could also have all 4 circles inside one shape layer.
  • Eric Chard
    February 3, 2021 at 7:32 pm
    Thanks: TIL that you can have separate blend modes for fill/stroke!
    I wound up parenting layers with empty fills because me no mograph so gud. If I were to redo this I’d just use ADD for the white strokes.
    Thanks for the help!
