Activity Forums Apple Final Cut Pro Legacy non-linked video
  • non-linked video
    Posted by Burns S on March 20, 2007 at 2:16 am
    Small question.
    For some reason when i import video the audio and video aren’t linked up anymore. I used to be able to move them together as one and if i would want to cut some video out i would have to select them both and hit “apple L” and then slice it. Now they just import unlinked. What have I done and how can i change it. I have selected both clips and hit to try to link them up both up but it doesn’t really work.
    any help would be greatly appreciated.
    Burns
    Burns S replied 19 years, 5 months ago 2 Members · 2 Replies
  • Steven Lambion
    March 21, 2007 at 6:52 am
    A couple of Solutions:
    1:
    In the timeline at the top right there is at least two shelf icons. One is two lines with circles at the ends pointing at each other with a magnetic pulse. This is to toogle snapping. the one next to this should be a Square wiith two squares inside it. This is to have the Video and audio tracks connected. Maker sure this is select(has green glow to it).
    2:
    Goto the Menubar -> Modify -> Link or command-L.
    Hope this Helps!!
  • Burns S
    March 31, 2007 at 7:05 pm
    It was the first. Thanks, i really scrached my head for a while on that one.
    thanks a ton
