Activity Forums Adobe After Effects Non linear scaling in AE
  • Non linear scaling in AE
    Posted by John Jay on May 1, 2005 at 1:21 pm
    Trying to get a plugin to remove lateral chromatic aberration without success –
    I have been pulling the red and blue channels using optics compensation which improves things but not at the extreme edges. I have concluded that I need to use a non-linear scaler ( sort of like a bath tub curve in the x and y directions) which is calibrated for my lens
    Any of you bright cookies know a way to do non- linear scaling in this way?
    Barend Onneweer replied 21 years, 4 months ago 3 Members · 5 Replies
  • Chris Smith
    May 1, 2005 at 3:32 pm
    My only thought is to split the clip into it’s 3 channels using the Channel tools. Then do an optics compensation on all 3 seperately, then SCREEN them back together. Haven’t really played with the optics compensation, I guess you are saying it works linearly?
    Chris Smith
    https://www.sugarfilmproduction.com
  • John Jay
    May 1, 2005 at 5:21 pm
    yes thats what I’m doing, but I leave the green alone since the lens is usually optimised on green
    the optics comp works best on diagonal scaling but is still not quite right since the idea is to effect a refractive index change/displacement rather than a barrel/pin correction
    maybe I could try a displacement map using a bw grad – but I will have to do it in 4 halves – top, bottom, left , right
    unless someone has the finger on the pulse for this sort of thing
  • Barend Onneweer
    May 1, 2005 at 7:34 pm
    Well, you could probably do a meshwarp, where you manually tweak the warp mesh to get the exact displacement you need.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • John Jay
    May 1, 2005 at 8:19 pm
    good suggestion – i will add to the list of things to try
    btw Barend if you have any pull with Adobe please ask them for CA correction in next After Effects release. They have it in Photoshop CS2 so it should be simple to port over.
  • Barend Onneweer
    May 1, 2005 at 8:37 pm
    Ha! I’ll let them know 🙂
    On another note: I haven’t tried the CA Corrector in PS CS2, but you could always do a batch on an image sequence in Photoshop, using its filter…
    Not the prettiest solution, but it would do it for now.
    Bar3nd
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
