Activity Forums Apple Final Cut Pro Legacy non-drop to drop frame
  • non-drop to drop frame
    Posted by L Isha on October 4, 2005 at 4:01 am
    Hello to all,
    I am working on a project for broadcast shot on dvcpro50 in non-drop. I have to deliver using drop frame. At what point in the workflow do I change the timecode to drop frame?
    As always, thanks in advance.
    Lisha
    Herb Sevush replied 20 years, 11 months ago 7 Members · 10 Replies
  • 10 Replies
  • Shane Ross
    October 4, 2005 at 4:08 am
    The moment you create your timeline. As long as your timeline is drop frame, you are good to go.
  • L Isha
    October 4, 2005 at 4:26 am
    Thanks Shane! 🙂
  • Walter Biscardi
    October 4, 2005 at 1:32 pm
    Not sure if DVCPro 50 is the same as DVCPro HD, but in the HD formats, everything is non-drop frame except true 60p recordings. Everything else edits as non-drop frame.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
    G5 Dual 2.0, AJA Kona 2, Medea FCR2X
  • L Isha
    October 4, 2005 at 4:03 pm
    I probably should’ve given more information… 🙁 Sorry about that, I was in a rush… 🙂
    The footage was shot DVCPro50, in 24P Advanced, at non-drop. I’ve imported the footage as non-drop. I am working on a G5 using FCP5. This is a multi-cam project. Yes, the video advisor on the set said DVCPro50 only shoots at non-drop.
    So Walter–or everybody ;-), do I simply make the sequence dropframe as Shane said in his post? Or is there more to it?
    Thanks so much!
    Lisha
  • L Isha
    October 4, 2005 at 4:10 pm
    …and if it edits as non-drop frame how do you deliver for broadcast? Doesn’t broadcast have to be drop frame. If I edit in non-drop and have to deliver 00:58:30;00 how can I account for accurate time?
    Thanks again!
    Lisha
    Dual G5, FCP 5, Blackmagic Decklink
  • Aaron Neitz
    October 4, 2005 at 6:22 pm
    that’s all you do. Switch it over to a drop frame sequence, make any adjustments to your TRT to fit the show specs. Quick n’ easy.
  • Walter Biscardi
    October 4, 2005 at 6:29 pm
    [L isha] “…and if it edits as non-drop frame how do you deliver for broadcast? Doesn’t broadcast have to be drop frame. If I edit in non-drop and have to deliver 00:58:30;00 how can I account for accurate time?”
    It edits perfectly to a drop frame HDCAM via FCP. In fact, I found out from one of the mastering facilities that an AVID can’t make the edit that FCP was making. That is, Edit to Tape from a non-drop timeline to a drop-frame Master tape. It would give an error of mis-matched timecode. But in our work here, we’re able to make frame accurate masters in one of two ways.
    1 – Master directly to HDCAM from FCP via HD-SDI
    2 – Master to DVCPro HD, take that tape to a mastering facility, and edit from a 1200A to an HDCAM deck feeding timecode from the 1200A.
    All of our masters have been dead-on to date so it’s working quite well here. Again, this is only with DVCPro HD, you just can’t create a drop frame timeline unless it’s true 60p.
  • Debe
    October 4, 2005 at 6:54 pm
    L isha–
    Just to ultra clarify for you, drop vs. non-drop is only an issue of frame counting. It’s not like mixing codecs or anything like that.
    You can edit non-drop footage in a drop sequence with no real ramifications, and vice versa. It’s just a counting scheme, nothing more.
    That’s one of the things I wish Avid would address. There’s no real reason you shouldn’t be able to put a non-drop frame timeline on a drop frame tape. It might not be wise to put a drop timeline on a non-drop tape if you’re making a broadcast master, and perhaps that’s why Avid won’t let you do either. To idiot-proof it.
    debe
  • Herb Sevush
    October 5, 2005 at 10:43 pm
    Walter –
    What do you mean by “true 60P recordings”?
    I’m editing with material shot with DVCPro HD 720/P60 and Drop Frame is not an option in FCP.
    Herb Sevush
    Zebra Productions
  • Herb Sevush
    October 5, 2005 at 10:44 pm
    Walter –
    Herb Sevush
    Zebra Productions
