Activity Forums Avid Media Composer Non drop frame tape detected Error
  • Non drop frame tape detected Error
    Posted by Russell Tafarella on October 27, 2008 at 6:33 am
    Hi Guys,
    I’m getting a message from avid saying “a non drop frame tape was inserted. A drop frame tape was expected. Please insert the correct drop frame tape?” What the heck does this mean. I set my deck to non drop frame and still the same msg. Please help!
    Piotr Niemcewicz replied 17 years, 10 months ago 4 Members · 3 Replies
  • David Braswell
    October 27, 2008 at 1:44 pm
    The deck merely reads existing TC so changing the setting there won’t help.
    Next time you insert the offending tape, simply rename it. The Avid basically looks for whatever the existing TC format was. You may have to clear the error message first, but renaming should take care of you.
  • William Busby
    October 27, 2008 at 8:26 pm
    I’ve found that simply playing the tape several seconds before opening the record tool fixes this. YMMV.
  • Piotr Niemcewicz
    November 20, 2008 at 10:06 am
    i have these trouble…
    project is broken
    i create new project, open old bin, import ready sequences to new project, and capture tape
    its work correctly
