Activity › Forums › Avid Media Composer › Non drop frame rushes modified to drop frame
  • Non drop frame rushes modified to drop frame
    Posted by David Hill on June 14, 2016 at 4:45 pm
    Hello
    I’m working on an American programme, being cut in the UK, where the there are two cameras: the master camera, which has been filmed drop frame and the slave camera which has been filmed in non drop. Yes – really.
    I also have wav files that were ingested as non drop (:) by the edit house. I have modified these to drop (;) so I can now Autosync the wavs and the master camera.
    My question is if I modify the slave camera from non drop to drop frame (this will allow me to then multi-group everything), will I create problems in the conform (I am working 10:1)?
    I hope this makes sense – the edit house I’m working out of weren’t too sure, hence this post.
    Many thanks.
    David Hill replied 10 years, 3 months ago 3 Members · 4 Replies
  • Michael Phillips
    June 15, 2016 at 3:27 am
    Yes – the conform for the clips you changed will be off by 2 frames after the first minutes, etc. due to the different counting schemes. I haven’t tried it, but can’t you create a common timecode in one of the AuxTC columns and group based on that?
    Michael
  • David Hill
    June 15, 2016 at 6:52 am
    Hi Michael
    Appreciate the response – I thought that might be the case – just needed it confirmed. I’ve never used the Aux. Time code grouping so will look into it.
    Getting people in the field to talk to each other would be a good start, too!
    Thanks again
  • Pat Horridge
    June 16, 2016 at 6:55 am
    Personally I’d have converted the drop frame to none drop frame and made a new master file of it. Then done all the post in non drop frame.
    Drop frame only really has any use in the final playout.
    Pat Horridge
    Broadcast & Post Consultant, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    pat@vet.co.uk
  • David Hill
    June 16, 2016 at 7:03 am
    Hi Pat
    Thank you for your response – I wish the edit house had used that technique before I arrived!
    It’s not something I’ve ever done (converting to drop) – I’ve never seen it as an option on transcoding; may I be so cheeky as to ask how to do this, then I can tell the edit house. It’s a long running project with many episodes and it would be good to have a fail-safe system.
    Thanking you again
    David
