Activity Forums Avid Media Composer Non-Drop frame Errors with 24P, HDW1800 and Nitris
  • Non-Drop frame Errors with 24P, HDW1800 and Nitris
    Posted by Ryan Megan on February 19, 2008 at 4:25 pm
    So recently my production company started shooting our HD shows in 23.98. (it had been 59.94 1080i). We still online and deliver in 1080i 59.94
    I was using a Sony M2000 for onlining up to this point but realized this deck does not have pull down.
    So after tedious discussions with our local deck specialist (has a strong asian accent very hard to understand) he suggested we swap one of our used M2000 with one of his new HDW-1800 which can do pull down. Oddly enough our cheaper JH3 decks handle pull-down fine (used to digitize 20-1 footage for offline edits). So I get the deck and plop in a 24p footage tape, set it tp it’s proper system frequency and all appears to be well. I was too swamped at the time to do extensive testing.
    But here we are now behind schedule trying to rush these new HD 24p shows out the door and wouldn’t ya know it, I run into problems for the online. For some reason this new deck will not recognize these tapes as drop frame. It insists they are non-drop. Oddly enough, once again the cheap JH3 decks have no problem with onlining the footage. Has anyone encountered a problem like this and have any ideas what so ever as a solution? Is there a setting that escapes me or is this a deck flaw.
    thanks in advance.
    Ryan Megan replied 18 years, 6 months ago 5 Members · 9 Replies
  • 9 Replies
  • Ryan Megan
    February 19, 2008 at 7:25 pm
    I think I’ve narrowed my problem down to a deck issue. BUt would still like feedback from anyone whom as working knowlege of the HDW1800.
    We’ve been using the JH3 in 23.98 (with pulldown) mode to digitize the offline footage. This deck has a setting for drop or non-drop. It seems the HDW-1800 although allows you to apply drop down, does not allow you to select “drop frame” it’s stuck in “non-drop frame”.
    I may have to just use the JH3 for onlines I guess. But feel a bit swindled as I was promised by my deck dealer this deck would handle my workflow just fine. Now with the shows cutting using the footage in drop frame, I can’t really online it in non-drop frame.
    Again any ideas or feedback would help.
  • Adam Polanger
    February 20, 2008 at 12:06 am
    From the Sony Product Page on the HDW-1800.
    https://tinyurl.com/29cqrf
    “Pulldown output is not available in this model”
    You digitized all your 24p source tapes at 59.94i (with pulldown). You need a deck like the HDW-F500 with the HKDV507D pulldown board installed. Here is some more info:
    https://tinyurl.com/ys64jy
    Without pulldown, the timecode and video coming out of the HDW-1800 will not be usable in a 59.94i project.
    Using the HDW-F500 with pulldown you can convert video and timecode to 30i DF or NDF
    You will need to set these menu items
    Timecode Sense Select 24p/30i
    Pulldown Control DF/NDF
    This will match the way you digitized the J-H3.
  • Adam Polanger
    February 20, 2008 at 12:13 am
    I hope this might help you.
    You were swindled by your deck dealer. If you want a more knowledgeable dealer let me know.
  • Derrick Abeyta
    February 20, 2008 at 12:25 am
    Did you try going in the main menu page? try pressing P1 (home), then P5 (page down) and then you should see F4 drop/non drop. Hope this helps.
    BTW, I was having the same problem when I first purchased the HDW D1800 deck. I was used to editing with the JH3.
    Derrick
  • Adam Polanger
    February 20, 2008 at 1:14 am
    The info I linked to seems to be out of date.
    There is a board called HKDW-104 that will give you 59.94i video & timecode if it is installed in your deck.
    Here is the manual:
    https://bssc.sel.sony.com/BroadcastandBusiness/minisites/cinealta/docs/hkdw104_opMan.pdf
    (English starts on page 8)
    I’ve never seen the deck but I am assuming you want menu items
    013 SYSTEM FREQUENCY SELECT set to 23.98PD1
    018 ACTIVE LINE SELECT set to OFF
    217 PULLDOWN TIMECODE SENSE set to ON
    There is no PULLDOWN CONTROL item like on the other deck, hopefully the pulldown timecode sense will default to DF like on the J-H3.
  • Scott Cumbo
    February 20, 2008 at 1:12 pm
    check the deck template in the avid, make sure it has 24p.
    example HDWF50024p… you may have to manualy adjust it by
    using the adjust deck option.
    if an 1800 template isn’t available you can use the 500 template.
    also, I know that their is a firmware upgrade for some of the 1800 decks, you may want to give sony a call. We’ve ran across a bunch of issue’s with our 1800.
    good luck.
    Scott Cumbo
    Editor
    Broadway Video, NYC
  • Ryan Megan
    February 20, 2008 at 5:53 pm
    thanks for the suggestions guys, really appreciate it. If none of this works I guess I’ll try to get Sony on the horn.
    The deck was sold (allegedly) with a card in it that allows pulldown – and sure enough there is an option for 23.98 with pulldown. I thought the 24p deck templates only showed up when in a 24p project. When I have the system frequency set to 59.94 the menu has an option for Drop/non drop. But the option vanishes when I switch modes.
  • Earle Nichol
    February 25, 2008 at 5:50 pm
    Hey guys, I just went thru a similar situation with our HDW-1800. Ours was an issue of getting a 59.94 timeline out of a 29.97 offline that had 23.98 source tapes. We should have just done the offline in HD(learned lesson) but with budgets and stuff and graphics to take into consideration, it is, what it is. Anyways, now with our 29.94 timeline and our 23.98 source tapes I thought we were in for a heap load of pain,(and I did try to figure it out over the weekend, with no luck) Anyways with the info that you posted I was able to walk in this morning, tweak our deck and get a 59.94 timeline for our client. After all my blithering, I just wanted to say thanks for the posting Adam, it saved our(my) butt. I LOVE THE COW!!!
    pearl
    Communication, Communication, Communication!!!
  • Ryan Megan
    February 25, 2008 at 6:25 pm
    Thanks for all the help guys.
    I ended up talking it through with a Sony tech – there were a few other deck settings in the menu that had to be tweaked that weren’t mentioned here. I was in such a flux I didn’t have time to jot them down. But I would say if the information posted here doesn’t get you all the way there give the Sony guys a call, the guy I spoke with was very pleasant and helpful.
