Activity Forums Adobe Premiere Pro noisy video
  • noisy video
    Posted by Garyl on September 18, 2007 at 5:49 pm
    Is there any way to remove noise from video? I was thinking like Noise Ninja will do on stills? Any suggestions?
    Perry Cheng replied 19 years ago 4 Members · 5 Replies
  • Vince Becquiot
    September 18, 2007 at 5:56 pm
    Try blurring the blue channel a bit. (Channel blur)
    There is no magic bullet…
    Vince
  • Garyl
    September 18, 2007 at 6:58 pm
    thanks Vince. You mentioned magic bullet. Do you think that the PREMIERE Plug-in is worht getting. if you want to make video look more like film will the premiere version do or do you need
    to get the After Effects version. Thanks Gary
  • Vince Becquiot
    September 18, 2007 at 7:12 pm
    I don’t. I mean, you would be better off saving your money for lenses / lens adpters and lighting. Of course, that’s much more expensive…
    I have used it, but I don’t own it. Most of what it does can be done with manual gamma and curve / level adjustments.
    Magic bullet just makes presets out of those adjustments.
    Anyway, I think it is worth owning if your footage is already up to PAR with a good film composition, but again, no miracles.
    Cheers,
    Vince
  • John Tissavary
    September 19, 2007 at 8:13 am
    The after effects version is far better, but your best bet is to run your footage through after effects and use its native grain/noise removal tool (used to be Grain Surgery until it was bought by AE). Works great, but render times can be a bit long depending on what exactly you’re doing in noise removal.
    Magic Bullet does have a ‘deartifacter’ plug in, but noise removal in AE is king. Also, I think you can use noise ninja in AE, but I’ve never used it.
    cheers,
    jt
    john tissavary
    luna cie, inc.
    digital film
    hollwyood
    http://www.lunacie.com
  • Perry Cheng
    September 23, 2007 at 12:09 am
    try: https://www.neatvideo.com/
    very good quality and but, long process time if you don’t have super powerful machine.
    Perry
