Activity Forums Maxon Cinema 4D Noisy Renders!
  • Noisy Renders!
    Posted by Ken on March 22, 2006 at 4:39 pm
    Hi…
    I have a stone texture that I’ve applied to the diffusion and bump channels of my material. Everything looks great, but when I render it as an animation, the texture seems to look “noisy”…lots of dancing pixels. I have a simple camera move on it an nothing else. Any idea how to fix this?
    Thanks in advance,
    Ken
    Ken replied 20 years, 6 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    March 22, 2006 at 6:47 pm
    Use MIP or SAT interpolation for the texture (in the material settings). Then you might need to adjust the MIP Scale in Render>AA settings upwards. If that doesn’t do the trick try using Best AA. To keep render times low you you use Best at 1×1, then assign a compositing tag to your rock object and set a higher AA level for it.
  • Ken
    March 22, 2006 at 7:48 pm
    THANK YOU!
