Activity Forums Audio Noisy Mic, Problems with new mic, or is it a problem?
  • Brian Reynolds
    February 3, 2014 at 6:50 am
    3.5mm connectors can be wired in many ways and this is often what causes so much confusion.
    Firstly a 3.5mm MONO connector has 2 connections tip (signal +) and the sleeve (signal -)
    A standard STEREO 3.5mm is wired on the 3 connections. tip (Left +) the ring (Right +) and the sleeve (signal -)
    This is the standard for most DSLR / Video cameras and handheld recorders like the H4n (on the back) as well as Headphones and Ear Bugs used on MP3 players.
    DUAL MONO this is to get the same signal to both Left & Right of the DSLR / Video camera….
    The (signal +) must go to BOTH the 3.5mm tip & ring and the (signal -) goes to the sleeve.
    This configuration is the standard that is required by most DSLR / Video camera people.
    On the other end the standard XLR connections are
    Pin 1 on the XLR is the shield used for blocking out interference on ‘Balanced’ audio equipment. (and does NOT carry any signal)
    Pin 2 on the XLR is (signal +)
    Pin 3 on the XLR is (signal -)
    Radio mics using 3.5mm connections are different again and we won’t go into that at this time.
  • Craig Alan
    February 4, 2014 at 2:04 am
    [Brian Reynolds] “a 3.5mm MONO connector has 2 connections tip (signal +) and the sleeve (signal -)
    Doesn’t that equal only one ring (+ the tip)?
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
  • Brian Reynolds
    February 4, 2014 at 3:50 am
    Here is some more info for you…
    https://en.wikipedia.org/wiki/Phone_connector_(audio)
  • Craig Alan
    February 4, 2014 at 6:01 am
    exactly: the two mono plugs have one ring the stereo plug has two.
  • Brian Reynolds
    February 4, 2014 at 7:57 am
    I assume that you are counting the ‘metal’ connection rings and not the plastic insulation?
    There are 3.5mm connectors out there with 2 ‘metal’ rings but they are used for mobile phones etc.
  • Matthew Gapp
    February 6, 2014 at 3:16 am
    What would be a good xlr based portable recorder for under 500 dollars. I want to have almost no noise in the sound. The r-05 i figured was the main problem for being noisy. I have tried all gains and levels.
    I really really really hate noise and static. I want professional sound.
  • Brian Reynolds
    February 6, 2014 at 6:39 am
    Fast, Good or Cheap. Pick two…..
    If there was a GREAT recorder under $500 we would ALL have one.
    It’s just a case the more $$$$ you spend the better it is.
    https://www.sixside.com/fast_good_cheap.asp
  • Matthew Gapp
    February 6, 2014 at 6:47 am
    I totally understand what you mean by that.
    Ill pick good and cheapish,
    What would you recommend?
  • Brian Reynolds
    February 8, 2014 at 11:53 pm
    There is a lot of stuff about recorders, the pro’s and con’s…
    The range is changing on a monthly basis, just find one that suits your needs ‘now’ with the full knowledge that in a years time your needs and what’s available will be totally different.
Page 2 of 2
