Activity Forums Adobe After Effects Noise When Using Keyligh
  • Noise When Using Keyligh
    Posted by Eric Goldstein on November 1, 2007 at 10:13 pm
    I’m using Keylight on a greenscreen. They key is generally good, but I’m getting noise in the shadows. I’ve tried various settings, but can’t get rid of it. Any suggestions?
    Eric
    Eric Goldstein
    Giraffe Film Company
    Los Angeles
    eric@giraffefilm.com
    Eric Goldstein replied 18 years, 10 months ago 4 Members · 10 Replies
  • 10 Replies
  • Mike Smith
    November 1, 2007 at 11:07 pm
    In the mask settings, how are your black clip (and white clip) settings …? You can check them of course by selecting mask rather than final output in the display drop-down ..
  • Eric Goldstein
    November 1, 2007 at 11:39 pm
    Hi Mike,
    I have carefully checked my black and white clip settings while viewing the matte – but can’t eliminate this noise in the shadows.
    Eric
  • Aaron Zander
    November 2, 2007 at 12:22 am
    check your screen gain. Keylight can add a lot of grain if you let it
  • Eric Goldstein
    November 2, 2007 at 1:05 am
    Screen Gain is currently set to 100.
    Eric
  • Aaron Zander
    November 2, 2007 at 2:55 am
    try turning it down a touch, also (don’t have it infront of me so I don’t remember the name) but the other adjustment setting up there with screen gain can be tweaked. THough the default is usually suitable there is a reason you can turn it down, as well as up.
  • Eric Goldstein
    November 2, 2007 at 3:43 am
    Thanks for the help. I’ll give it a try.
    Eric
    Eric Goldstein
    Los Angeles
  • Mike Smith
    November 2, 2007 at 11:51 am
    Interesting. I know we’re checking basics here, but there’s no noise in the shadows on your background before keying …?
  • Eric Goldstein
    November 2, 2007 at 1:34 pm
    No, The image is clean. The noise only appears after keying.
    Eric Goldstein
    Los Angeles
  • David Bogie
    November 2, 2007 at 2:28 pm
    What’s the original format of the video?
    If you check it on a scope, what do the red and blue channels look like in those areas?
    I don’t do much chromakeying in AE these days and my personal experience with Keylight has always been killer even with DV. But all of my high end keying in AE has required careful masking and application of various assistant filters to copies of the key layer. Matte chokers, spill suppressors, masking, hole patches, light wrap, all that stuff.
    bogiesan
  • Eric Goldstein
    November 2, 2007 at 3:36 pm
    Thank you for your help. I’ll get back after I try some of the suggestions.
    Eric
