Activity › Forums › Adobe After Effects › Noise when Chroma Keying
Posted by Derek Hader on July 20, 2006 at 5:20 pmHey,
I have access to Ultra, but i perfer to use After Effects whenever possible… just a personal preference. The problem is, when I key my green screen footage in AE, it always seems to come out with a lot of noise/grain even tho the only effect I’ve used is Keylight. When I key the same footage in Ultra, it comes out much cleaner.
I’m keying well-lit DV footage using Keylight in AE 7.
Any ideas or pointers to reduce this noise would be greatly appreciated!
Skeets
Erik Pontius replied 20 years, 1 month ago 5 Members · 7 Replies -
Fabiano Peres
July 20, 2006 at 6:12 pmTo solve this, on Keylight change the view to “Combined Matte” and at “Screen Matte” increase or decrease the values of “Clip Black” and “Clip White” try to get the bigger contrast of back and white possible…
The black areas are the ones that will not be seen in the final comp.I hope it helps.
Eddy Alvarez
July 20, 2006 at 7:34 pmif you clip the black and whites in the screen matte section…do a screen pre-blur by half a point or third of a point..to soften any hard edges..
or add a simple choker effect at half a point…so your edges come smoother
Fabiano Peres
July 20, 2006 at 7:57 pmClip black and white as I told you right before, it will solve the problem.
Barend Onneweer
July 20, 2006 at 8:33 pmIf the noise is in the matte, then increasing the matte contrast by pulling the levels as suggested will help.
It sounds though as if you’re seeing amplified noise caused by spill removal. See if disabling the spill removal in Keylight helps.
FWIW – I usually apply a pass of Remove Grain before keying.
Bar3nd
Forum COWmunity leader for:
ADOBE AFTER EFFECTS
MAGIC BULLET SUITE
INDIE FILM & DOCUMENTARY -
Erik Pontius
July 21, 2006 at 2:24 amAs others have said, use the status view to see how much to clip white/clip black. Also adjusting the screen strength option very slightly might help as well.
You might also find that you are having to clip black by a large degree to get the majority of the background to key (unevenly lit, wrinkles, etc…). I’d recommend following Aharon’s tutorial on super-tight junk mattes. This way you remove most of the background and only have to worry about a small portion to process with keylight. Also, Andrew Kramer’s tutorial on keylight is a good down and dirty intro to keylight.
Keylight will use a color to replace spill being removed, often adjusting this color from the default grey color may help.
Another option is to tell keylight just not to process the majority of the face by drawing a mask around the center of the face and setting keylight’s “inside mask” option to this mask.
Keylight’s thick manual is a good read as well as it goes into some of the more advanced features that might be of help as well (screen/alpha bias, color correction, etc…)Erik
