Activity Forums Apple Final Cut Pro Legacy noise reduction plugin for fcp?
  • noise reduction plugin for fcp?
    Posted by Gregg Grossman on October 18, 2010 at 4:32 pm
    hi – i know this topic has been covered in other posts but some of threads seem to be old and i was hoping to get some fresh suggestions.
    i’m working on an 80 min doc and using stp for the audio post … without going into the details i’ve experienced almost all the bugs described in countless posts on this and other boards. it’s a real disappointment … in any case, the main thing stp has that i need and fcp doesn’t is a good noise reduction tool.
    i’ve tried soundsoap but can’t seem to get the plugin to work with fcp – maybe i’m missing something so any suggestions would be great with regard to soundsoap / fcp.
    that said, any recommendations about other plugins would be greatly appreciated.
    thanks a lot
    Michael Gissing replied 15 years, 10 months ago 2 Members · 3 Replies
  • Michael Gissing
    October 18, 2010 at 9:48 pm
    If you are finishing in STP, then do the noise reduction there. FCP is not an audio finishing tool, just a basic editor when it comes to sound so wait until you get to STP. If you need to check a clip then you can round trip it to STP and use the better tools there to EQ and noise reduce.
  • Gregg Grossman
    October 19, 2010 at 3:00 am
    Thanks – I understand. Unfortunately, my experience with STP is that it’s so buggy it’s almost useless.
    Constant low resource warnings, crashes, erratic results in round trips using multi track projects … STAPs seem to work more reliably but I have at least 200 clips in the TL so it’s a pretty tedious process to send everyone of them to STP as an Audio Project.
    I’m a relative novice and totally open to advice about the workflow if you have any to share. I have read STP seems to be more more stable when working with shorter seqs so I’m gong to break it up into 15 minute chunks and see if I have better luck.
    Appreciate you taking the time to reply.
  • Michael Gissing
    October 19, 2010 at 12:00 pm
    I use Fairlight so I don’t know what the issues with STP are. I use iZotope NR plugins (VST). iZotope is a great noise reduction system and can operate standalone on Mac and PC, but it will be a pain denoising individual files and then resyncing the new audio to each clip.
