Activity Forums Apple Final Cut Pro Legacy Noise reduction Help Needed
  • Noise reduction Help Needed
    Posted by Kat Nofs on July 7, 2005 at 2:40 am
    I plugged into a DJ’s sound board this weekend for my buddy’s toast. While he was speaking, there was this terrible hum coming thru the speakers and by the time I got my headphones on to see if it was being recorded, the toast was done and the music coming thru sounded fine. The DJ said he had NO idea why it was doing that. It was more of a buzz than a hum.
    I’m wondering what can be done to quell this God awful sound.
    Thank you!
    K
    John Fishback replied 21 years, 2 months ago 6 Members · 7 Replies
  • 7 Replies
  • Andrew Yoole
    July 7, 2005 at 3:57 am
    Soundtrack Pro (bundled with the new Final Cut Studio) has a pretty decent noise removal filter.
  • Jerry Hofmann
    July 7, 2005 at 3:58 am
    Got Soundtrack Pro? (Part of new Studio)… it has a feature that will work really well for this… the buzz isn’t going to be easy to delete with FCP I’m afraid.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Samuel Frazier
    July 7, 2005 at 7:13 am
    It’s a great primer for noise reduction and will tell you a lot of what you need to try to deal with your problem:
    https://www.dv.com/news/news_item.jhtml?LookupId=/xml/feature/2003/rose0903_feature
  • Peter
    July 7, 2005 at 8:16 am
    have you looked at sound soap or noise reduction by sony?
  • Kat Nofs
    July 7, 2005 at 12:26 pm
    No I do not own the new Soundtrack , just the one that came with FCP HD . I dont have any other software either. I was just hoping that something on FCP would at least reduce the buzzing….
    K
  • Jerry Hofmann
    July 7, 2005 at 2:11 pm
    About the only thing to do then is play around with different notch filter audio filters. Might be able to notch out some of the noise that way, but if the frequency of the noise is the same as the audio you want to preserve, its really not gonna work very well because you’ll notch out that too. I’d suggest if you have the bugdet to go to an audio studio with pro tools and have them work on it… or someone with Soundtrack Pro maybe could come to the rescue.
    Jerry
  • John Fishback
    July 8, 2005 at 12:27 am
    Checkout this thread that may offer some ideas to reduce the noise you are hearing:
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?univpostid=839315&forumid=8&postid=839510&pview=t
    John
    Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
    Dual Cinema 23 Radeon 9800
    FCP4.5 DVDSP 3.0.2
    Huge U-320R 1TB Raid 3 firmware ENG12.BIN
    ATTO UL4D driver 3.20
    AJA IO driver 1.3.1 firmware v21-26
    SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
