Activity › Forums › Apple Final Cut Pro Legacy › Noise reduction converting VHS to DVD
Posted by Niklas Wikman on May 8, 2009 at 4:33 pmI’m recording VHS over DV25 for later export to DVD.
Is there any noise reduction tools in FCP, that are useful prior to encoding to MPEG-2?
I’m also thinking of encoding MPEG-2 with 352×576 resolution, instead of 702×576. Then the DVD player will automatically scale the picture. Since it*s VHS, I figure there’s no point in encoding at 702×576 anyway.
Any thoughts on this is greatly appreciated.
Niklas
Arnie Schlissel replied 17 years, 4 months ago 6 Members · 9 Replies -
Steve Eisen
May 8, 2009 at 4:24 pmSoundtrack Pro!
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Niklas Wikman
May 8, 2009 at 4:39 pmAh, sorry!
Should have been more precise. I’m not after doing AUDIO noise reduction, rather VIDEO noise reduction.
Any tools for that in FCP? 🙂
John Pale
May 8, 2009 at 4:56 pmThere is a video noise removal filter in the Filters Pane in Compressor.
I think I would encode at full frame size, rather than throw away any more data.
John Fishback
May 8, 2009 at 4:56 pmCheck out Noise Reduction and Smart Noise Reduction at https://www.mattias.nu/plugins/ One of the best noise reduction programs is Innobits’ Video Purifier https://www.innobits.com/purifier.html
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Rafael Amador
May 8, 2009 at 4:59 pm[Niklas Wikman] “I’m also thinking of encoding MPEG-2 with 352×576 resolution, instead of 702×576. Then the DVD player will automatically scale the picture. Since it*s VHS, I figure there’s no point in encoding at 702×576 anyway. “
To clean the noise of a movie is a waist of time when you intend to do such destructive capture.
When I work with a low quality source I try, at least, don’t degrade it more.
rafael -
Niklas Wikman
May 8, 2009 at 6:02 pmYou misunderstood me.
I capture at DV25 720×576.
My idea was to encode MPEG-2 with 352×576 instead of 704×576. There’s really no need for full resolution since you have already lost that much from the original VHS footage.
I’ll have a look at Video Purifier and the free Noise Reduction suggested here.
Arnie Schlissel
May 9, 2009 at 3:48 pmI think that what Rafael was trying to point out is that you’re converting a low quality analog format to a highly compressed digital format with low color sampling- DV. You’re only going to add compression artefacting to whatever other problems you already have. It would be better to capture it to an uncompressed or less compressed format like ProRes or DV50.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Rafael Amador
May 9, 2009 at 4:51 pmHi Arni,
Niklas want to make a ‘half size” DVD because he thinks that the source is already of low quality.
In the other hand he want to de-noise the movie.
For me, sorry, this makes no much sense. He cares about the noise but not about the picture being blow-up by a DVD player.
Is like if you brush the hair of your dog but you don’t feed him.
rafael -
Arnie Schlissel
May 9, 2009 at 5:00 pm[Rafael Amador] “Is like if you brush the hair of your dog but you don’t feed him.”
That’s a great analogy! I’m in complete agreement. If he want’s the best quality, he can start with a better capture and should end with a full height DVD. It won’t be the same quality as a studio picture, but I don’t see the point of putting all that effort into NR when you capture as DV and end up as half height.
FWIW, I’ve made half height DVDs when I needed to fit around 4 hours on a disk, and it did look better with that much compression than the full height did. But at more reasonable (and typical) compression levels, the full height is waaaay better.
Arnie
