Activity Forums DaVinci Resolve Noise reduction causing color/gamma shift after playback/render
  • Noise reduction causing color/gamma shift after playback/render
    Posted by Ty Delgaty on July 27, 2023 at 5:15 pm
    When I add a noise reduction to a node, everything looks fine, but when I play back the clip, on the second loop, the gamma and color suddenly shift. I’ve noticed the blue shadows, specifically get raised, and all the detail is lost. In my troubleshooting, it seems to only affect the shadows if they are clipped. Again, everything looks fine on the first play, it’s as though once the FX is cached it bugs out. I have tried clearing my renders. Another note, even if I disable the plugin (as in, switch it off in the FX tab, NOT disable the node), the problem persists. So to be clear, I turn the FX OFF, and the issue is still there.
    Some before and afters, notice the detail in the shadows: https://imgur.com/a/hgFlzYf
    Any ideas? Seems like a bug. I have updated my Nvidia studio drivers too.
    Cheers.
    View post on imgur.com
    Ty Delgaty replied 3 years ago 1 Member · 1 Reply
  • Ty Delgaty
    August 10, 2023 at 3:24 pm
    I thought I would respond with the solution to this for whoever comes across this issue. Turns out, when using a wide gamut color managed workflow, you need to have your render resolution set to DNxHR 444 in order to retain details in the shadows.
