Activity Forums Adobe Encore DVD Noise on Video after transcoding
  • Noise on Video after transcoding
    Posted by Julio Crespo on October 8, 2006 at 4:01 pm
    I allready make DVD from a video captured (in premiere 1.5) from VHS tape when I edit a little bit, I Export to a .AVI and make a little menu to the DVD When I play the video its look like noisy and have scanline crossing the screen, It look like a 70’s video. somebody have this problem before?.
    Julio Crespo replied 19 years, 11 months ago 2 Members · 2 Replies
  • Vince Becquiot
    October 9, 2006 at 4:06 am
    The noise maybe normal, since DVD compression really doesn’t do well with already noisy input, which would be the case of a VHS.
    The scan lines you are referring to maybe a wrong field order, that is usually accompanied with “jerkiness” in motion areas. You will need to know whether you imported your footage in lower or upper field first.
    Vince
  • Julio Crespo
    October 10, 2006 at 5:48 pm
    I render the video from Premiere with the Lower field first
