Activity › Forums › Apple Final Cut Pro Legacy › Noise in the soundtrack in Final Cut Pro
  • Noise in the soundtrack in Final Cut Pro
    Posted by Fernando Lino on July 27, 2010 at 3:10 pm
    Hey
    Every time I import a music to my sequence I hear this repeated noise two times every second and I don’t know what’s happening. It’s almost like the sound of music not rendered but not as loud. I checked the settings and it seems fine, it didn’t used to happen.
    I would really be appreciated if you could help me out.
    Fernando Lino replied 16 years, 2 months ago 2 Members · 6 Replies
  • Mark Petereit
    July 27, 2010 at 3:25 pm
    What is the frame rate of your sequence? And what is the source of the music you’re importing?
  • Fernando Lino
    July 27, 2010 at 3:34 pm
    25 frames the sequence. I’m importing the video from a external disk and the music from my main disk. Do you think that it might be related to that?
  • Fernando Lino
    July 27, 2010 at 3:40 pm
    Yeah I’m using mp3s, I can’t find the music in question in another format. What do you suggest? To convert the audio files?
  • Mark Petereit
    July 27, 2010 at 3:46 pm
    I know most people dread hearing this, but you really ought to try reading the manual.
  • Fernando Lino
    July 27, 2010 at 4:39 pm
    Thanks a lot! The sample rate of the song was 44.1 khz and I converterted it to 48 khz.
    To be honest I have just read a few pages of the manual. The works keeps pilimp up and i haven’t found the time to read it. I was amazed of how concise it is, i’ll definitely will try to find the time to read it.
    Thanks again.
  • Fernando Lino
    July 27, 2010 at 4:40 pm
    Thanks! I used the batch export of FCP. The sample rate was of 44.1 khz and i converted it to 48 khz…
