Activity Forums Adobe After Effects Noise in Key
  • Noise in Key
    Posted by Evan Thomas phillips on April 27, 2007 at 8:27 pm
    I’ve got some footage that I’m keying: Green screen, shot on DV, brought in with Blackmagic 10bit 4:2:2 via Component, using keylight on AfterEffects 7 Pro, MacPro with Intel chips. The key looks good, but people’s hair and black or white shirts are picking up a lot of digital noise. The edges aren’t the problem at all. The parts effected don’t even have any green spill. Is this a Keylight bug? (It doesn’t show up in the footage until after using keylight)
    Evan Thomas phillips replied 19 years, 4 months ago 3 Members · 5 Replies
  • Iancorey
    April 27, 2007 at 8:34 pm
    That noise is likely compression artifacts in the green channel that get removed by applying the Keylight effect (leaving ‘holes’ in the footage). I’ve heard tell that you should de-noise your footage first. Just tell. I’ve never done it myself. Maybe there’s something in the forums about it.
  • Darby Edelen
    April 27, 2007 at 9:05 pm
    [IndieSoon] “Green screen, shot on DV, brought in with Blackmagic 10bit 4:2:2 via Component”
    Just curious, is there really a benefit to bringing DV footage in at 10bit 4:2:2?
  • Evan Thomas phillips
    May 1, 2007 at 4:42 pm
    My experience with DV being captured via firewire is that the footage ends up with a lot of digital noise that you don’t notice until you do something like keying. The noise will prevent you from getting good edges. I’ve been coming in 8 or 10 bit via component on a blackmagic multibridge, and it smooths out all the noise.
  • Darby Edelen
    May 3, 2007 at 5:26 am
    Does it actually do a good job of upconverting the 4:1:1 color compression?
    May 4, 2007 at 7:00 pm
    The BlackMagic card does a great job of upconverting from 4:1:1. It looks just like seeing DV being played off the original tape onto a really good broadcast monitor.
