Activity › Forums › Adobe After Effects › “noise” in hair
  • “noise” in hair
    Posted by Brian Atchley on October 5, 2011 at 4:53 am
    I am trying to become more “advanced” at compositing, and here is an issue I would like to learn how to solve:
    I just pulled a key and the dark areas in th man’s hair seem to have a lot of “noise” and don’t seem to blend well with the background. Any suggestions on how to eliminate this and just get a nice, solid dark brown color?
    Jeff Brown replied 14 years, 11 months ago 5 Members · 4 Replies
  • Angelo Lorenzo
    October 5, 2011 at 5:38 am
    As a caveat, this question is so broad and we don’t have a screenshot of exactly what you’re doing so take this with a grain of salt.
    It’s usually better to add noise into your keyed background than vice versa.
    My background is in professional retouching for print. A big tip-off for recognizing fake elements is their inherent lack of grain or noise.
    If you want to remove noise, there are a number of plugins that do so at different price points, I like Red Giant’s Denoise https://www.redgiantsoftware.com/products/all/magic-bullet-denoiser/features/
    Alternately I’ve had no problem throwing After Effects “Add Grain” effect onto footage for a more real look.
    – Angelo Lorenzo
    – https://FilmsFor.Us Sell your film and connect with your audience
  • Ben G unguren
    October 5, 2011 at 6:36 am
    I agree with Angelo that a screenshot would be very helpful in this instance. In case this isn’t about grain, but about a rough (or shaky) edge around the hair, then here are some thoughts:
    – Do a separate key for the hair. This allows you to mess with some settings that wouldn’t work as well for the rest of the body but is ideal for something where there are a lot of fine lines.
    – Sometimes you need to make a key to generate the alpha matte, and then you do a second “key” to color the image (remove the green, etc). Then you combine these. This is a process I often undertake when dealing with a more detailed key and/or varied edge detail.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Tudor “ted” jelescu
    October 5, 2011 at 4:36 pm
  • Jeff Brown
    October 5, 2011 at 7:50 pm
    One big issue is: what is your source footage? Improving that is usually the easiest way to get a better key.
    -Jeff
