Activity Forums Adobe After Effects noise in grey suits
  • noise in grey suits
    Posted by Claudia Gabriela on April 14, 2014 at 5:51 pm
    Hey guys,
    I’m keying someone using Keylight who is wearing a grey suit. for some reason, its causing a lot of noise? I’m being told to color correct it, but i don’t really know what to DO with the color correction in order to fix it. I’ve tried playing with contrast, hue, saturation, levels, etc but it seems to look the same. is there someone out where who would know exactly what i need to play with in color correction to make the noise less severe? any advice helps. thank you!
    Kevin Camp replied 12 years, 4 months ago 4 Members · 5 Replies
  • Michael Szalapski
    April 14, 2014 at 5:56 pm
    Look at the actual key that’s being pulled. Keylight gives you the option to view that sort of thing. Work on making that key a bit cleaner.
    Then, set Keylight to render the intermediate result only and use a different tool to do spill suppression.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Claudia Gabriela
    April 14, 2014 at 6:11 pm
    thanks
  • Michael Szalapski
    April 14, 2014 at 8:00 pm
    [Claudia Gabriela] “thanks”
    No problem!
    Here’s a thread where someone had a similar issue and Dave LaRonde has some great suggestions.
    – The Great Szalam
  • Jerry Wise
    April 14, 2014 at 8:27 pm
    you might look at “screen matte” and select “source” instead of the default “soft color”
  • Kevin Camp
    April 15, 2014 at 4:26 pm
    setting the replacement method from ‘soft color’ to ‘hard color’ can often help and this method still allows you to use keylight’s spill suppression.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
