Activity › Forums › Compression Techniques › noise in black
  • noise in black
    Posted by Bob Cole on November 25, 2005 at 7:35 pm
    I’m using the Digital Rapids 500 card and the base level Stream software. I like the real-time encoding, but I’ve struggled with a problem:
    Whenever there is a true black (fading in, for example) the “black” is really a noisy, moving swirl of artifacts — very dark gray, ugly and disturbing. I’ve noticed that using a higher bitrate makes the black a bit blacker and less noisy.
    I have seen this in encodes from other sources as well. I’ve considered changing all my fade-ins to dissolves from a dark texture, which seems to work better.
    — BC
    Bob Cole replied 20 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
