Activity Forums Compression Techniques NOISE and ALIAS in HighRes Mpeg2
  • NOISE and ALIAS in HighRes Mpeg2
    Posted by Francesco Glavina on February 11, 2010 at 3:13 pm
    Hi all. I’m in big trouble with Compressor. I’m trying to export a movie in MPEG2.
    I’m using high resolution settings but my videos have an high level of compression, border of sharp objects appear with a lot of aliasing and on dissolve the video flicker.
    Someone Can help me?
    I post here my settings:
    Mpeg2 1920*1080 29.97fps progressive
    Teo pass VBR , Best
    Average Bit Rate: 30 Mbps
    Maximum Bit Rate: 40 Mbps
    Francesco Glavina replied 16 years, 6 months ago 2 Members · 4 Replies
  • Daniel Low
    February 12, 2010 at 3:09 pm
    https://forums.creativecow.net/readpost/20/862073
    Sent from my iPad Nano.
  • Francesco Glavina
    February 15, 2010 at 8:59 am
    Thanks Daniel.
    MacPro 2.8 Ghz Quad-Core Xeon
    6GB RAM
    Mac OSX 10.5.8
    Output from FCP 7.0
    1920*1080 (HDTV 11080i 16:9)30fps “no compression” progressive
    Compressor 3.5
    Settings:
    Teo pass VBR , Best
    Destination use: playing on PC.
  • Daniel Low
    February 17, 2010 at 12:29 am
    [francesco glavina] “1920*1080 (HDTV 11080i 16:9)30fps “no compression” progressive “
    that makes no sense:
    Is it interlaced or progressive?
    This is likely where all your problems lie. Is your source interlaced and then you are exporting from FCP as progressive, or what?
  • Francesco Glavina
    February 19, 2010 at 4:02 am
    No, it’s all progressive. As i writed over. It’s from a 3d and all progressive.
