Activity Forums DaVinci Resolve Nodes Acting Strangely
  • Nodes Acting Strangely
    Posted by Charlie Herrick on January 22, 2019 at 7:22 pm
    I have my primary grade branching off in two directions: one branch to apply the grade, and one branch to isolate skintones; the two branches combine in a layer mixer down the chain. The skintone branch begins with a skintone isolation node, using HSL Qualification in combination with tracked power windows. Directly after that, I have an outside node to make adjustments that I don’t want to affect the skintones.
    For some reason however, the existence of the outside node completely kills the effect of the skintone isolation node—EVEN when it’s been bypassed. When I bypass the skintone it just turns off the outside node.
    I’m a bit new to this so I’m not sure what’s going on. Any ideas appreciated! Thanks!
    UPDATE: I think this is somehow the result of Power Windows. I separated my skintone nodes into: one for face, one for hand, each with the same HSL Qualification and it’s own tracked Power Window. When I delete the power window in the 2nd (hand) node, the 1st (face) node works properly. HOWEVER: I can’t get the hand node to work unless I completely delete the face node…
    Charlie Herrick replied 7 years, 7 months ago 2 Members · 2 Replies
  • Marc Wielage
    January 23, 2019 at 5:31 am
    Take a screen shot of your node tree and post it. It would be easier to visualize your setup rather than reading what you’re trying to do.
  • Charlie Herrick
    January 23, 2019 at 7:43 pm
    Thanks for the reply!
    I think I figured it out: I was adding my skintone nodes right after one another in a single separate branch before combining them with the rest of the grade in a layer node down the chain—when I added another input to the layer node and made each of my skintone isolations as parallel nodes, it worked.
