Activity › Forums › Adobe After Effects › No Video Tab/Player
No Video Tab/Player
Posted by Dean Fischer on December 10, 2009 at 8:26 amThere is no video tab in the AEcs4 that I have. And since there is no video tab there are no players.
Do I need to download the progressive player separately?
Thanks.
Steve Roberts replied 16 years, 9 months ago 2 Members · 5 Replies -
Steve Roberts
December 10, 2009 at 4:23 pmGo to the top right and look for the drop-down menu that says “workspace”. Choose “standard”.
Now if you want to see the composition window, you need to make a composition.
If that doesn’t help, you’ll have to clarify your problem, since I (for one) don’t know if you’re using the correct terminology.
Dean Fischer
December 10, 2009 at 5:53 pmI did what you said.
On the right panel where animation effects, audio and all those category tabs are there is no “video” tab. I’m pretty sure that there is supposed to be a video tab. Right?
And thanks for your reply!
Dean Fischer
December 10, 2009 at 7:38 pmSo exporting a video from AE which includes a player is not possible?
Dean Fischer
December 10, 2009 at 8:45 pmI apprceiate your help and I apologize that I’m causing you ambiguity……sometimes I have ambiguity towards myself, so I understand.
What I’m trying to do is export a flash/flv movie.
I guess it’s Adobe flash that exports a player but not AE.
Steve Roberts
December 10, 2009 at 11:28 pmFlash can export a lot of things: SWF, HTML, EXE in a package if you want. AE just exports the FLV when you choose to export/render FLV.
If the user has downloaded the latest Adobe Media Player, he/she should be able play the FLV. If not, he/she most likely cannot play the FLV.
Instead, you would want to export an SWF from AE to make something that can be played with little discomfort on the user’s part.Right, Flash gurus?
