Activity Forums Apple Final Cut Pro Legacy No Video Playback from Sequences
  • No Video Playback from Sequences
    Posted by Sam Goldstein on September 10, 2008 at 9:00 pm
    OK, totally weird, but I’m under deadline and need to fix this ASAP.
    Raw footage from the browser plays fine through multiple outputs (mirror, AJA IO, Desktop Preview). If I render and do a Print to Video, the sequence will also output fine.
    The problem is… No sequence from any project will play video. It was working fine and then… nothing.
    I’ve toggles View/All Frames, restarted FCP, rebooted the mac, trashed preferences to no avail.
    Help, please.
    -Sam
    MacPro 2×2.66Mhz, 2GB Ram, LaCie Biggest F800, AJA IO, AJ-HD1200A
    Sam Goldstein replied 17 years, 11 months ago 2 Members · 3 Replies
  • Sam Goldstein
    September 10, 2008 at 9:14 pm
    resetting pram did not fix either.
  • Kevin Maguire
    September 10, 2008 at 10:53 pm
    Is VIEW / WIREFRAME selected?
  • Sam Goldstein
    September 10, 2008 at 11:52 pm
    That was it. Thank you so much! I was about to re-install the software. It’s always the dumbest things.
    Thanks Again, you rock.
    -Sam
