Activity Forums Adobe Premiere Pro No video overlay on monitors!
  • No video overlay on monitors!
    Posted by Wookiepet on July 8, 2006 at 3:40 pm
    Video appears on monitors on a freeze but does not play, just goes blue when playing or scrolling. I run with Premiere Pro 1.5 and DVStorm2 Pro. Nvidia NX6200TC card. Any suggestions would be welcome, I have downloaded the latest drivers etc. Odd thing is that Device manager also finds 4 monitors when I only have dual monitors… could this be a factor??
    Brett Howe replied 20 years, 2 months ago 2 Members · 2 Replies
  • Brett Howe
    July 9, 2006 at 7:57 am
    I’m no expert, but are u sure u are running the right drivers.
    The 4 monitor thing sounds like it’s a windows/driver/card issue, rather than a p pro issue!
    just my 2 cents worth
    Cheers
    Brett
  • Brett Howe
    July 9, 2006 at 8:11 am
    Oh, and another thing.
    If you don’t have enough video memory (it get shared accross monitors) this can cause a problem. I have a similar setup, with a storm card etc and ran into the same hassles.
    1st, does the video window play on your primary monitor only?
    If so, your card can’t handle the overlay on the second monitor. This can be cured by A./ setting up your workspace with the preview windows on Monitor 1. or B./ go into the settings for overlay memory, and you should be able to load the monitor u want to use for video playback.
    I don’t know much about your card, so good luck!
