Activity Forums Blackmagic Design No video output with Decklink 5.5 for Windows XP x64 with Decklink HD
  • No video output with Decklink 5.5 for Windows XP x64 with Decklink HD
    Posted by Michael Großmann on March 29, 2006 at 12:26 pm
    Hardware:
    K8WE S2895 (Bios 1.01)
    dual Opteron 246
    4GB registered DDR Kingston
    Windows XP x64 SP1
    At first I installed the software (Premiere Pro 2.0 and Combustion 4.02 with Quicktime 7).
    If I use the Memhole Mapping-Switch in the BIOS so that I can get the full 4GByte the driver installation stops with a blue screen after the Decklink Display.
    If I don’t use the switch during the installation and switch it on after the installation the system hangs up with a Bluescreen-error in the Decklink.sys after rebooting.
    Without activating the Memhole Switch in the Bios the Installation works but there is no Video output over HD-SDI output in Premiere Pro 2.0. The System shows only 3GByte instead of the effective installed 4GByte Memory.
    In Combustion 4.02 I cannot open the video files created with 5.4 drivers (audio only in the thumbnail-view) so I couldn’t test the Framebuffer. In the C4 preferences there was only the RGB output settings available instead of the YUV setting (for Decklink HD).
    In 32Bit I don’t have any issuses with the output.
    regards
    your “beta tester”
    M.Gro
    Michael Großmann replied 20 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
