Activity Forums Blackmagic Design No video input in my decklink HD pro dual link video card
  • No video input in my decklink HD pro dual link video card
    Posted by Manuel Deo on June 10, 2006 at 2:57 pm
    Hello,
    i Have a decklink pro hd dual link, in me computer and i can’t grab video SDI.
    On the overlay appears this message ” No video input”.
    I change my HD decklink card and i install and decklink pro, and i continue to have the same trouble.
    Somebody has successed the solve this kind of trouble??
    thank for your help
    MAnu
    Manuel Deo replied 20 years, 2 months ago 2 Members · 2 Replies
  • Kristian Lam
    June 11, 2006 at 8:20 am
    Hi Manu,
    Firstly, what kind of deck are you capturing from?
    What format is your video? PAL or NTSC?
    Are you capturing using FCP or Blackmagic Deck Control?
    PC or Mac?
    regards
    Kristian Lam
    Blackmagic Design
  • Manuel Deo
    June 11, 2006 at 2:34 pm
    hi kristian,
    my deck is an sony dsr 1500ap, with a sdi board. The sdi output is good, because i can see it on my monitor with sdi inpu. So, i’m sure my signal from my deck is good.
    I use windows xp 32 bit OS.
    and i capture the picture with the decklink card and i control the deck with the decklink remote.
    I have try some test which i read on the forum.
    I have put the sdi outpout to the sdi input decklink, to be sure, but the overlay says that no input. I have digitiez this no input video.
    I have do this test with blackmagic software directly.
    With premiere pro 2.0, it’s the same trouble.
    i HAVE THE KASTEST BIOS OF MY MOTHERBOARD SUPERMICRO 2.0 VERSION FOR X6DAE-G2, AND I HAVE PUT THE LATEST DRIVERS OF DECKLING 5.6.
    I have change my pci connection to try the card ( test on the 3 PCI-X of the motherboard)
    Everything work, the audio, the display, the serial port, every thing but not the input acquisition.
    I’m a little bit lost.
    So i have trouble too with the xp 64 bit edition, the systeme crash when i install the display drivers. I install the others drivers ( audio, remote…) but when i try to installed the dribers display the computer scrashe.
    If you have an issue for the input video on xp 32, i appreciate.
    thank for your help
    regards
