Activity Forums Blackmagic Design No video input Help!
  • No video input Help!
    Posted by Dan Phillips on February 20, 2006 at 10:38 pm
    All
    I have installed the Decklink HD Pro single link and tried the 5.2.2 and 5.4.2 drivers and get no video input. I have tested the line on an SDI monitor and video is coming. Help please.
    Dan Phillips replied 20 years, 7 months ago 2 Members · 3 Replies
  • Kristian Lam
    February 20, 2006 at 10:45 pm
    Hi Dan,
    Please provide more information.
    1) What make / model of deck (or source) are you capturing from?
    2) What format of video are you capturing and to what codec?
    3) Did you use the easy setups provided by us in Final Cut Pro? They are located in Final Cut Pro>Easy setup…
    regards
    Kristian Lam
    Blackmagic Design
  • Kristian Lam
    February 20, 2006 at 10:54 pm
    Forgot to ask you for your system configuration details as well. Please let us know the operating system version, hardware configuration etc.
    regards
    Kristian Lam
    Blackmagic Design
  • Dan Phillips
    February 21, 2006 at 12:29 am
    Kristian
    I tried capturing to SD 8 and 10 bit as well as DV/DVCPRO and just get the no video input. The output works when extending the desktop.
    The Video is coming SD over SDI. I have tried it from directly from the SDI out of a DVCPRO deck, an XDCAM deck and through our Ross Gear router. Everything we have is in a rack and routed through a routing system.
    Here is my setup:
    3DBOXX S5i
    Model Specifications
    Windows XP Professional SP2
    Dual Intel
