Activity Forums Blackmagic Design “No Video Input” Decklink HD Pro Dual PCI-X
  • “No Video Input” Decklink HD Pro Dual PCI-X
    Posted by Jan Schulz on June 27, 2006 at 11:28 am
    i just replaced a Decklink Pro with a Decklink HD Pro Dual Link. SDI and analog outputs are fine.
    The Problem is: I get neither HDSDI nor SD-SDI input at all.
    Yes, i uninstalled the previous driver. The card sits in the 133 Mhz slot and the problem occurs in FCP and
    the BM Deckcontrol-Tool using any easy setup.
    I tried different cables and connecting the deck (Sony JH-3) directly to an HD-Link to veriy it is outputting correctly.
    It is.
    Driver is version 5.6
    Any ideas, Gentlemen?
    Manuel Deo replied 20 years, 2 months ago 2 Members · 3 Replies
  • Manuel Deo
    June 27, 2006 at 4:37 pm
    Hi Jan,
    Infortunatly, i have the same problem like you.
    I have the logo “no video input” in my decklink overlay.
    So i can’t help you, but my system has 4 gb of ram, and i have read this :
    https://blackmagic-design.com/support/detail.asp?techID=160
    I try to take off 2 Gb.
    I do this test and i tell you if something good happens
  • Jan Schulz
    June 29, 2006 at 9:46 am
    Solved my problem by putting the decklink in the middle pci-x slot.
    Now I have 1 seritek sata card in the lower and one in the upper slot.
    I know this is not recommended since the lower and the middle slot might slow each other down.
    Seems to work though.
    I can caputre 1080 50i 8Bit (haven’t tried 10bit yet) and both of my sata arrays operate at about 250 MB/s.
    Wish youd good luck with getting yours to work!
  • Manuel Deo
    June 30, 2006 at 3:02 pm
    hi Jan,
    unfortunality, i have try to put the decklink in another pci x slot ,but always the same no video input.
    Thanks for your help,
    maybe to morrow is a better day
    manuel
