Activity › Forums › Apple Final Cut Pro Legacy › No video in capture window while capturing
  • No video in capture window while capturing
    Posted by Chaz Shukat on November 19, 2005 at 2:17 am
    I’m sure this is a settings thing but when I’m capturing there is no video in the capture window. It is capturing but it’s not showing in the window. Does it have something to do with it showing “preview disabled” in the viewer? If so, how do you enable preview?
    Chaz S.
    Chaz Shukat replied 20 years, 10 months ago 2 Members · 2 Replies
  • David Battistella
    November 19, 2005 at 7:12 am
    If you are capturing HDV then you will not see video while you ae capturing.
    Also check to make sure that you are capturing Audio and video in the capture window.
    David
  • Chaz Shukat
    November 25, 2005 at 1:43 am
    I am not capturing HDV and interestingly, the next day there was video in the box, then the following day it was gone again. ?????
    Chaz S.
