Activity Forums Boris FX NO VCR buttons BR!!!
  • NO VCR buttons BR!!!
    Posted by Sergio Anaya on May 29, 2006 at 4:49 pm
    I have this problem, When I install BR 3.0 is ok but when I install the update to 3.0.4 I have not VCR buttons in the composite window!!! Why is this? Anyone with the same problem? how to solve it?
    I mostly use Red as alone engine even I edit with LE 6.1 and Red works as plugin on it.
    Sergio Anaya replied 20 years, 3 months ago 3 Members · 3 Replies
  • Mark
    June 2, 2006 at 12:58 pm
    TRy deleting the preferences and then restarting the application. If you are on windows, the preferences is an .ini file Do a search on your c drive for *.ini and delete the one that comes up for Boris Red. If you are on a mac, then I am not sure where it is other than it should be where all preferences are stored.
    Hope this helps
    Mark
  • Paul Fx
    June 2, 2006 at 7:26 pm
    In Start > Control Panel > Display, go under the Settings tab and click on Advanced. See that the DPI for your computer is set to Normal (96 DPI)it should be in the General tab.
  • Sergio Anaya
    June 12, 2006 at 4:11 pm
    I alredy did it, but I had not sucess, any other advice??
    You know, it is funny because this happen only when I up date and in any update I get a window message telling me ” wait, serching for stuido.mod file” can this file be the problem I have?
    Regards
