Activity › Forums › Adobe Photoshop › no vanishing point in CMYK space?
  • no vanishing point in CMYK space?
    Posted by Illusboy on August 20, 2005 at 5:47 pm
    hello i made a picture with a digital camera that i converted to CMYK for print purposes in photoshop CS2.
    The problem i’m having is that i can’t use the vanishing point filter wen the image is in CMYK, why is that?
    any help is appreciated.
    illusboy
    Illusboy replied 21 years, 1 month ago 2 Members · 2 Replies
  • Richard Harrington
    August 20, 2005 at 11:17 pm
    Many filters only work in RGB space…
    Copnverting to CMYK is the FINAL step… it is best ro work RGB throughout (faster processing, more options, etc.)
    Converting back to RGB from CMYK won’t shift colors.. the shift occurs when going to thCMYK the first time as RGB has a wider gamut.
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Illusboy
    August 22, 2005 at 9:14 am
    thanks i did not know that!
